Top speed of 400ex
Old Apr 8, 2004 | 08:32 PM
  #21
2untouchables690's Avatar
Default Top speed of 400ex
drummerguy84 does your brother have his throttle screw turned in or does he weigh 300 lbs. because the 400ex does about 65-68 because I ride with about 5 of them, and I also ride with 3 blasters and a blaster goes around 55 and a blaster and a 300ex go about the same speed so I know he can't even keep up with a 400ex because we race all the time
also I heard something about 99 400ex's going faster than they should but not 90 mph and I don't believe they would make a quad in 1999 go faster than the 2000,2001,2002,2003,and 2004's.
also I wished the raptor did 85 stock I have heard numbers for the raptor from 72-81 but wind, weight, tire pressure, if you are on flat ground going up or downhill, andthe terrain you are riding on will affect speed
Old Apr 8, 2004 | 09:55 PM
  #22
MrTrendy1's Avatar
Originally posted by: drummerguy84
gotta rember...I;'m sure theres 2 modes on that device...MPH...and KPH...sure it wasnt kilo per hour?..my bro has a 400EX..I draged it...we were neck and neck..both throttled out...and my bike only goes 55-60mph
Yeah, I know there are two different things, MPH and KPH. But I also know that if I were only going 65Mph and it was set to KPH, it would have told me near 100Kph. There is a huge difference there. Plus, I only weight 130lbs so I get an ideal run on the bike because of the little weight added. I could have hit 75mph on mine with ease, probably near 80mph doing on the slight 15 degree downward slope. Each bike will run differently. I might just have a 400ex that can do the higher speeds than other peoples. Plus I think due to my body size, I can achieve faster speeds. My friend got on it and could not top it but only at 50mph. He weights 300lbs.
Old Apr 8, 2004 | 10:17 PM
  #23
maddog56's Avatar
Back off guys and let the newbie have his day...
I will as well, of course.
Old Apr 8, 2004 | 11:40 PM
  #24
BRAD14's Avatar
im gonna have to say 65-69mph.
Old Apr 9, 2004 | 12:05 AM
  #25
Guest
Guest
Posts: n/a
I hit 69-70 with mine stock according to my gps
Old Apr 9, 2004 | 12:49 AM
  #26
Yeah, I know there are two different things, MPH and KPH. But I also know that if I were only going 65Mph and it was set to KPH, it would have told me near 100Kph. There is a huge difference is a huge difference there. Plus, I only weight 130lbs so I get an ideal run on the bike because of the little weight added. I could have hit 75mph on mine with ease, probably near 80mph doing on the slight 15 degree downward slope. Each bike will run differently. I might just have a 400ex that can do the higher speeds than other peoples. Plus I think due to my body size, I can achieve faster speeds. My friend got on it and could not top it but only at 50mph. He weights 300lbs.
what mods do you have??? because I have a friend with big gun pipe, big gun cdi, kn air fliter, and big gun rectifier, and he weighs 105 and he only hits 75mph on pavement with no wind on flat ground so if you have a stock 400ex that goes 75 where can I get one?? also you say your 300 lb. friend can only do 50 on it well umm my friends ex that I mention well he has an older brother that weighs 220 and it only loses about 4 mph and that's about 115 lb. difference I guess the extra 55 lbs. makes it about another 21 mph slower I don't know
ohh well who cares just ride
Old Apr 9, 2004 | 02:39 AM
  #27
spade's Avatar
Originally posted by: crappycustoms
My best friend has a 400ex the only mods are White brothers R-4 series and it has been jetted& K&N. And it goes every bit of 85 mph. He says it would prolly be 65-90. When the 400's were made there were a few that ran faster and a few that ran slower. So, all depends. His sisters boyfriend, bought a new 400 and stock it ran 90, but he broke it in right. too, that is a big factor in the end. So all depends but I would say 65-90 some where in there? Weird margin aye?
did honda have a barrel of sprockets to pick out of to determine the speed of each 400ex. Are you serious about a stock 400ex doing 90mph then you are really dumb because my bone stock 450r does 76mph and i really smoked my friends 400 ex with white bros e-series muffler with pro comp header and power filter. It wasn't even close so before you start blabbing sh*t you should find the real info.
Old Apr 9, 2004 | 02:42 AM
  #28
spade's Avatar
Originally posted by: Shav0
dirt wheeles says 71.
a raptor can only do about 80-85, so no way a ex can do anything even close to that.
dirt wheels says a lot of bs because a stock raptor only does 74-76 mph. Maybe a piped and filtered with jets might do 80-85, maybe. Also there are regulations from factory machines that make them top out of 75 mph at the most. 80-85 is retarded for a stock raptor
Old Apr 9, 2004 | 10:33 AM
  #29
drummerguy84's Avatar
i dont even know why they would make thoes machines go that fast..your never going to top it out on a MX track...maby trails...
Old Apr 9, 2004 | 11:08 AM
  #30
sickmojave's Avatar
I have gotten my 03 400ex up to 90 MPH
but it was in the back of my truck [img]i/expressions/face-icon-small-wink.gif[/img]
