Rearend going out on 300ex
Old Jul 20, 2000 | 05:00 PM
cjudd's Avatar
How much are new rear end bearings and seals for the 300ex how easy are they to put on
Old Jul 20, 2000 | 05:11 PM
THEXOTIC1's Avatar
The bearing kit from a dealer or oem Honda part supplier is about 50-60 for 2 bearings and 2 dirt seals. Try a local bearing supplier you can get the bearings cheaper from them. The honda bearing part number applies for all bearings. I paid about $11 each for the bearings and $4 each for the dust covers. You will also need some type of bearing grease or marine grade grease and a bearing puller to pull the old bearings out.
Old Jul 20, 2000 | 05:35 PM
Moses's Avatar
I did it without a bearing puller. Just stick a long screwdriver in the opposite end of the bearing carrier and pop it out with a hammer. I'm sure it's not the recommended process, but it works. And set the carrier on a piece of wood so you don't ding it up when you are pounding on it.
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
Wiley wolf
Sep 7, 2015 08:32 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
