quick question on changing a CV boot
Old Apr 11, 2004 | 11:37 PM
CatKrazy's Avatar
Default quick question on changing a CV boot
its for a honda 450es 99 model. What can i use to remove the band holding the boot in place?
And what tool can I use to reattach and tighten a new one. What is the tool i need called?
Thanks
Old Apr 12, 2004 | 12:48 AM
Polaris500HO4x4's Avatar
if u dont want the band u have on there now take a needle nose and tear the bitch off thats what i do.
now to put it back on take a flat head screw driver push down on the band where it needs to get bent over and push hard so it doesnt moove( after u have it tight enough) now bend the band back over top and keep tension on it then bend over the little metal flaps and thats all u need. it doesnt pay to spend 20 bucks on a tool u wont use much
Old Apr 12, 2004 | 01:18 AM
CatKrazy's Avatar
But what do you use to put the Bitch back on with?
Old Apr 12, 2004 | 01:21 AM
flat head screw driver and a needle nose pliers. put it on the sleeve and put the band around it then pull it really tight and push the band down the the screw driver and fold it over. then pinch the 2 little metal strips over the band and make sure there tight. its not as hard to do as im makin it sound lol. it should be ok
Old Apr 12, 2004 | 01:23 AM
CatKrazy's Avatar
Ok thanks I appreciate it!
Old Apr 12, 2004 | 01:24 AM
i try maybe i can explain it better tomorrow after i sober up a lil but more. i was with the family all aft.
Old Apr 12, 2004 | 01:25 AM
CatKrazy's Avatar
Ok sounds good. Just let me know!
Thanks
Old Apr 12, 2004 | 01:27 AM
do u have your boot and band laying around
Old Apr 12, 2004 | 01:33 AM
it goes like this lemme try
_______
__________ll<<<
l l
l l
l__________l
right at this point there should be a metal plate with two
metal flaps on the side like this l__l the band goes under
first then gets folded back over the top and the 2 flap should get pinched down hard so the band doesnt move
really there isnt much to that at all its a 20 minutes job for me and im no pro at this. lol sorry about my non sence drawing hope that helps a little bit
Old Apr 12, 2004 | 01:35 AM
ok that didnt work at all sorry man
