Choke Question???
Old Apr 15, 2004 | 08:51 AM
rickytz7111's Avatar
Default Choke Question???
I have a rancher AT. I have a question about the choke. When it is warm outside like 70 degrees I pull out the choke but it never goes to a fast idle it just kind of starts it and thats it. I tried starting it this morning with the choke fully out and it went up to fast idle pretty quick. It was 45 degrees when I tried starting it this morning. Is this normal or should it fast idle it any time when I pull the choke cable fully out? The quad only has 70 miles on it. Thanks for any inputs.
Old Apr 15, 2004 | 01:56 PM
Does anyone have this problem???
Old Apr 16, 2004 | 09:41 AM
Can anyone help me out???
Old Apr 16, 2004 | 10:04 PM
dzzy's Avatar
There is no mechanical "fast idle" per se built into your carb. There is a fuel enrichener and some circuitry in your carb which will allow it to fast idle under certain conditions. Mainly, if the temperature is cold enough. In other words, it's just a simple carb, not like fuel injection which monitors half a dozen different conditions and adjusts the fuel duration accordingly. At 70F, the mixture at full choke is too rich to fast idle. It may however, fast idle to a certain extent at partial enrichener settings (half choke). It doesn't sound like anything is wrong with your wheeler.
Logan Collins
Sep 5, 2015 08:03 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
WesTech
11
Aug 11, 2015 07:55 AM
ghost civic
Jul 27, 2015 03:15 AM
