honda 300ex valves
Old Jul 22, 2000 | 01:53 PM
Honda300ex#2's Avatar
i just got my quad out of the shop after a complete topend rebuild valves,valve guides,valve seats,piston,rings. In the first ten min of riding it just shut off and wouldn't start i took it back to the shop and they found that one of the exhaust valves were bent. i would be glad if any of u guys could tell me what would cause the valve to bend. one more thing they said the motor was timed properly so it couldn't have been the timing. thanks in advance for the help
Old Jul 22, 2000 | 05:49 PM
Tree Farmer's Avatar
Stock piston?
Stock cam (lift)?
High-compression pistons/high-lift cams, without adequate piston-top relief cuts for the valves, can produce interference--otherwise, hard to imagine how a true valve could become bent in normal service . . .
Foreign object bouncing up and down atop the piston?
I'd like to know the answer, too!
Tree Farmer
Old Jul 22, 2000 | 11:56 PM
tree farmer it bored .20 over in the stock cylinder amd it has the stock cam
Old Jul 23, 2000 | 02:33 AM
SUP440's Avatar
I agree with TF. The piston they used probably didn't allow enough clearance for the valves.
Asaran
Oct 8, 2015 11:14 AM
hondarider1234
Jul 21, 2015 11:53 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
MNatv89
Jul 7, 2015 11:36 AM
