250R O-ring
Old Jul 23, 2000 | 01:13 AM
Snapper_Rider's Avatar
I have an 86 250R. I just took off the pipe that was on it to put on a new on and it look like there is a spot on the exhuast flange for an O-ring. I looked on the old pipe and couldn't find one. Is there supposed to be one there? Thanks
Old Jul 23, 2000 | 10:49 AM
dunerash's Avatar
yep.. there is one there a big snap ring that you havto compress to get the pipe back on.. i think it was like 15 bucks
Old Jul 23, 2000 | 03:18 PM
87_250R's Avatar
i will have to check if mine is there. i have a little leek when i rev it up to like 7000 rpm's. Can u explane what all is suppose to be there. i know there is a ring that bolts to the engine and then 2 springs hold the pipe on. (i can't remeber what els when i toot it off) i should paint it or i'am thinking about ceramic coating it
Old Jul 24, 2000 | 02:26 AM
250Racer's Avatar
yes there is a big steel snap ring and also a little exhaust gasket also. go to your local honda dealer and get them. I havent had any luck with the aftermarket getting these 2 things right.
86 250R
to many mods to list
Old Jul 24, 2000 | 10:55 AM
retro's Avatar
I found that even with a new exhause ring my exhaust still leaked. Some of the better pipes will seal better but most do not, the good ones use a gasket in the pipe. Try using some high temp. gasket compound/silicone. I think Permatex(spelling?) makes some good stuff.
ERIC
Old Jul 24, 2000 | 06:59 PM
87_250R's Avatar
the pipe is a moto-fast and it sealed with the dg silencer now is has a fmf and when i put it on i had the pipe loose i can push it back in and going to use that hight heat sealer
Old Jul 24, 2000 | 07:36 PM
Witz's Avatar
I found the cure to a leaky exhaust manifold was to replace it with RPM's machined manifold that uses 2 hi-temp o-rings, instead of the single steel ring that the stock flange uses. I never had much luck in getting a stock flange to seal up for very long, no matter how much hi-temp RTV was used. The RPM flange is a bit expensive, but works! I have one on both of my 250R's and neither leaks a drop.
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
ghost civic
Jul 27, 2015 03:15 AM
CRamshaw777
Jul 18, 2015 05:46 PM
