250R Blowing Headlight Lamps
Old Apr 20, 2004 | 02:15 AM
Evokiller's Avatar
Default 250R Blowing Headlight Lamps
I'm having a problem with my R blowing headlight lamps. A while back the stator went out and was replaced with a new 200 watt Ricky Stator. This stator from day one seemed to be lacking output power at low speed and normal at high speed. If the voltage regulator is shorted could I be supplying to much voltage to the headlight causing them to burn out in 5 seconds. I believe the regulator is the main problem. The next question is will a stock regulator handle the 200 watt stator.
Any input is welcome
Thanks Glenn
Old Apr 20, 2004 | 01:26 PM
td250r's Avatar
Check with Ricky Stator, he is pretty quick in responding by email. I am also considering this setup, so let me know how it turns out.
Old Apr 20, 2004 | 03:37 PM
DaBeechMan's Avatar
could be a faulty rectifier
Old Apr 20, 2004 | 06:52 PM
bansheeesmoker's Avatar
rectifier sounds like , is it stock and what lights are you using ,how many watts?
Old Apr 21, 2004 | 12:33 PM
Evokiller's Avatar
The regulator was the problem. Just wanted some feed back before spending the money. Thanks too all who responded.
Glenn
Whitelx1
Oct 2, 2015 10:55 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
