400ex big bore kit???
Old May 31, 2004 | 11:22 PM
Thenumber1rider's Avatar
Default 400ex big bore kit???
What big bore kit should i get to re-bore my 400ex. Is the CT or Whitebros racing one any good.
Old Jun 1, 2004 | 12:18 AM
SpeedDemon13's Avatar
go to trinityracing.com and get the 465 stroker...thats a big diff.
Old Jun 1, 2004 | 03:02 AM
esmaster07's Avatar
Don't bore over the 400EX, just get a Predator or Raptor if you want more power.
Old Jun 1, 2004 | 07:38 PM
cals400ex's Avatar
its fine to bore out an ex. if someone is having a problem either another part was broke inside or it was installed incorrectly. i have been running a 406 (.040 over) for quite some time and it is extremely reliable along with the 416's. when you get to the 426's your sleeve is getting thin and after that you need to put in a new sleeve. if they are built correclty, you shouldn't have a problem. its not a bad idea to install a larger oil cooler when doing the modifications either. i am building a 426 now and i have been told they are really reliable if you don't go over 11:1. more power will cause more stress as we all know. after 11:1, a heavy duty rod is highly recommended.
Old Jun 1, 2004 | 07:40 PM
cals400ex's Avatar
also, learn how to jet a carb. it is important to know what each of these jets do and where they are located. jetting after modifications will entitle changing the mainjet, pilot jet, adjusting fuel skrew, and changing the clip position on the needle.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
