Honda 400ex top speed
Old Jun 6, 2004 | 09:37 PM
thewayout420's Avatar
Default Honda 400ex top speed
it has a aftermarket aluminum airbox,he is jetted to run with that box.he is using a k&n with a prefilter also..
Old Jun 6, 2004 | 09:58 PM
Guest
Guest
Posts: n/a
Mine is stock and i hit 69 mph no mods at all with my garmin gps
Old Jun 7, 2004 | 05:09 PM
cals400ex's Avatar
adjusting the throttle cable can give you 5mph's if it is all the way in
Old Jun 14, 2004 | 11:57 AM
siggnasty's Avatar
Yeah dude, i donno about 5, maybe like 3 or so....5mph is alot for jist adjusting the throttle cable
Old Jun 14, 2004 | 03:18 PM
  #15
Yellr400EX's Avatar
http://www.kg4vpv.com/~ncliborne/400ex.htm[L=400ex gearing calculator]
Old May 26, 2013 | 06:30 PM
  #16
Pstroke96's Avatar
I have k and n and white bros e slip on pipe on 01 400 ex with stock sprockets jets and tires and get about 65 with wheel lift in 1 2 and 3 as well
Old Jun 1, 2013 | 05:07 PM
  #17
Loki1699's Avatar
I've never hit top end, 57 across choppy sand at night was as fast as I've had mine before we ran out of room. Mine is all stock '05.
Old Aug 30, 2013 | 09:33 PM
  #18
Turdpeterson's Avatar
my 2004 400ex tops out at 70mph, its got a edlebrock carb, k&n filter and HMF exhaust, and open air box, no idea if it has engine upgrades bought it used
Old Aug 31, 2013 | 09:35 AM
  #19
MarioWeldingInc's Avatar
Supposedly..... Just by swapping out sprockets you can get a factory 400ex into the high 70s low 80s but it takes a while to get there. Need a real long road. I never tried it so I dont know for sure.
Old Oct 12, 2013 | 02:50 PM
  #20
400ex-rider's Avatar
Default 2005 400ex top speed
your not gonna get a 400ex to go 80, my 400ex will do a max of 68-70mph if i have it topped out and i have a full exhaust system uni air filter with k&n power lid and 155 main jet sitting on 20" tires my brothers 450r will just do 80 and it has hotcams and a high compression piston
