Installing a Hot Cam
Installing just the cam won't do a whole heck of a lot. If you throw in a higher compression piston (which you can get for about $120), then you will notice quite a change in the quad.
Both can be done pretty easily with the shop manual, if you have half decent wrenching skills.
Since it's a brand new bike, you could go with the stock bore 11:1 piston and save those rebores for later and save little cash. They say you should hone the cylinder before you drop in the piston so the rings will seat right.
I put a stage 2 hotcam in my friends 400ex. His other mods are a fmf pipe and open airbox with K&N. With the cam it gave a lot more mid range and top end power. The engine wants to keep reving now, it doesnt level off like before. The only downfall is he lost some low end power. To fix this he bought a 39mm fcr carb. The carb gave a nice gain through the whole power range. Plenty of low end, pulls good all the way through top end.
He did not want to change the piston yet, these mods worked very well togather. Im sure a high comp or big bore piston would help out quite a bit.
