Is this stuff compatible?
Old Jun 19, 2004 | 07:26 PM
400exmagician's Avatar
Default Is this stuff compatible?
I just ordered a K and K jetting kit and a uni filter.
Will i still get maximum performance with this setup?
thanks for the input
Old Jun 19, 2004 | 07:58 PM
420EX's Avatar
dont you mean K&N? or did you order it from K&K? you will get a bigger power increase from a K&N filter but it doesnt filter out any dirt, good job getting the UNI, it's a great filter.
Old Jun 19, 2004 | 11:06 PM
lol thanks
and yes i mean K&N of course...
how much power loss do u think i will suffer with having a uni filter instead of K&N?
Old Jun 20, 2004 | 12:34 AM
cals400ex's Avatar
you probably won't notice much of anything with just a filter. if you add a pipe or remove the air box lid and rejet, you may notice something then. i probably would have just bought individual keihin jets and not the dynojets. it would have been cheaper. just so you know, the dynojets and the keihin jets have a different numbering pattern. so a 155 keihin is NOT the same size as a 155 dynojet. i actually prefer the uni filters also. they will flow a little less air than K&N but they will pass less dust particles thru too. the K&N's are nice for the dunes from what i read. also, with just a uni filter, you shouldn't even need to rejet more than likely.
Old Jun 20, 2004 | 12:49 AM
Actually, i do have a full dmc alien exhaust and am about to mod my air box along with a uni filter
so with a K&N jet...what do u think i should set it to?
Old Jun 20, 2004 | 01:23 AM
hondarider300's Avatar
if you have a jet kit, they usually come with jetting sugjestions for the quad. so see what it says and it will probobly be pretty close
Old Jun 20, 2004 | 02:42 AM
420EX's Avatar
the DMC full system is about the best out there, I would recommend an aluminum airbox for $65.00 off ebay from this guy "granitegear" it relocates the battery and look a whole lot better than the stocker, it's really strong too.
Old Jun 20, 2004 | 05:04 AM
cals400ex's Avatar
the kit will say somewhere around a 170 probably. however, there is no way i would go that big. your just going to run a bit rich and have a lower power output than you could have. i would try around a 155 dynojet (K&N jet kit).
Old Jun 20, 2004 | 05:33 AM
420EX's Avatar
the DMC exhaust is very free flowing so a much bigger jet is in order
Old Jun 20, 2004 | 01:50 PM
ya thats true, i have noticed that it flows extremely stong and the outake on it is tremendous.
i agree it is one of the best out there, at least i like it lol
so i should set it around 160-165...or is that too high?
