hondasaki
Old Jul 7, 2004 | 08:29 PM
250xRKrider's Avatar
Default hondasaki
i enjoy calling my, in process of being built, mod quad that! i'm just wondering wat all of you think about my new mod quad. it is going to be called a kxf295x. i'm in the process of building a quad using an 87 tecate 4 295cc big bore motor, with a 87 trx250x frame. the frame is going to have 400ex a-arms and suspension. it has a +4 durablue axle, realtor tires, nerf bars, maier race cut fenders, etc... the motor will use an aftermarket pipe, 39mm PWK keihin carb, uni air filter, and PVL ignition. i plan to use this atv for either flattrack racing or GNCC racing, and i will set it up accordingly to which type of racing i choose. i want to know ur thoughts on this, and wat type of racing i should do it in, also, how well do u think it will do? thanks to all u who post replys!
Old Jul 7, 2004 | 10:20 PM
Quad4Fun's Avatar
Default hondasaki
Sounds like quite the project, good luck. Post when you get it done and let us know how it works for you.
Good Luck
Old Jul 7, 2004 | 11:02 PM
Default hondasaki
thanx Quad4Fun! i am really lookin forward to starting the project, but i'm still waiting for the tecate motor to get here to CT from Mississippi. its been taken a really long time... the guy i purchased it from sent it out 4 monday's ago by UPS ground, and as of just last tues it was still in knoxville, so its taken them way too long! i'll be happy when its here [img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 8, 2004 | 12:27 AM
Eceriderjbomb's Avatar
Default hondasaki
The only real problem I could think of is the big exhuast hitting the frame but you have nothing to worry about if you make your engine mounts go further back closer to the swing arm but that would mean a smaller chain
Mr350X's Avatar
Default hondasaki
Sounds awesome.. but one suggestion.. kxf295x, needs to be kxf295R.
(2 stroke!!!)
Old Jul 8, 2004 | 04:27 PM
Default hondasaki
good thinkin Mr350X! i def will have to call it that from now on!! becasue it def is a 2 stroke!!
RDZ350
Where to Ride
11
May 22, 2006 09:03 PM
