400ex out of oil!?!?Help!
Old Jul 23, 2004 | 05:52 PM
wheelinforlife's Avatar
Default 400ex out of oil!?!?Help!
I just checked my oil i have not rode my wheeler for about 2 weeks and i checked the dip stick and theres no oil on the dip stick at all!!!! what the heck i check it pretty often too. what damage did i do to my wheeler if i did ride it on that for a little bit and what should i do? thanks
Old Jul 23, 2004 | 06:14 PM
400EXRiderJeff's Avatar
Idle it for 5 minutes, turn it off then check it again.
Old Jul 23, 2004 | 06:37 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
do an oil change,,,,and see how much was in there
Old Jul 23, 2004 | 07:24 PM
cals400ex's Avatar
the 400ex has a tendency to use a little bit of oil. switch brands of oil and the problem may diminish. i have had good luck with mobil 1 15w-50.
Old Jul 23, 2004 | 07:41 PM
hondaguy13's Avatar
if it runs out of oil it will melt your piston
Old Jul 23, 2004 | 10:32 PM
I use Hondapro HP-1 10w40, and I haven't lost any oil yet. It used to use up oil but it quit when I switched to HP1 so I'd go to your dealer and try that out. And yeah whover posted after me that would be a much better idea [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 23, 2004 | 10:49 PM
Tocky's Avatar
the oil tends to go from the tank to the crankcase if you let it sit for a long period of time...i would listen to 400exrider and let it run for a few before u check it......(as long as you knew there was oil in it and there isnt a gigantic puddle on the floor)
Old Jul 23, 2004 | 11:13 PM
insaine's Avatar
actually the 400ex is the hardest thing ever to check the oil in. you can check the oil where its sitt n and it will not show anything, and then roll it back 6 inches and it will show full. that is pretty stupid. honda is dumb, and i still cant get the fu*king axle nut off. ahhhhhhhhhhhh HONDA.
Old Jul 24, 2004 | 03:10 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
It's what Jeff and Tocky said. When these external oil tank bikes sit (Z400 does the same thing), the oil drains into the crankcase. Just start it for a couple of minutes (unless you have a 2 quart puddle of oil on the garage floor), and the oil pump will refill the tank. Then check the level.
I run Honda HP4 oil (a synth/petroleum blend), and highly recommend it.
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
