Honda Recon Electrical problem diagnosis...
Old Aug 4, 2004 | 01:11 AM
WhalerDude's Avatar
Default Honda Recon Electrical problem diagnosis...
1999 Honda Recon (TRX250) with an electrical problem - any suggestions?
This ATV will not charge the battery. With battery removed, it does not produce enough power output to light the headlamps beyond a dim glow, and the green neutral light will brighten slightly as the RPMs climb but then drop to a dim glow.
Where should I look to address this problem?
Thank you for your assistance!
Old Aug 4, 2004 | 04:02 AM
RancherS01's Avatar
Hmmm, I had this same problem on my Big Red, turned out to be a bad ground wire. Check all your grounds, clean em up if the are rusty or anything. I believe I tested the stator (alternator?) to make sure it was within specs. If you can get a hold of the service manual it should have the specs it should be within. My guess is it is one of those 2 problems.
Old Aug 4, 2004 | 02:28 PM
hondabuster's Avatar
Sounds like a bad battery. Charge it up, and have it load tested, at Autozone or Napa.
honda recon 250
Jul 3, 2015 01:50 PM
honda recon 250
Jun 24, 2015 04:52 PM
Jun 24, 2015 01:40 AM
Jun 10, 2015 12:45 AM
'86 TRX125
Jun 6, 2015 07:43 PM
