how to pop a wheelie
Old Aug 22, 2004 | 07:26 PM
  #21
SickRider's Avatar
Default how to pop a wheelie
Cool but I have a 400EX and in 1st All I have to do is barely press the gas at all and it's stock. I can even lean forward and punch it about half way and it will come up on me all the way so the grab bar is almost touching.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Aug 22, 2004 | 08:26 PM
  #22
4wheelerfred's Avatar
what kinda quad dose he have??????????????? y dont he reply?????????? i bet he tryd to do what you ppl told him and got hurt!!!!!!!!!!!!! atvs r not ment to do **** like that, ride it on the trail , y try somthing retarded...
Old Aug 22, 2004 | 09:46 PM
  #23
DarkManX's Avatar
if you are asking y try stupid stuff like wheelies? bc its FUN and awesome
Old Aug 23, 2004 | 10:50 AM
  #24
y know y.......... it's just a nother way to beat on your quad.. that meens money to fix it... and you not riding for a wile wen you brake your arm's...
Old Aug 23, 2004 | 11:01 AM
  #25
JoshCVBz's Avatar
I've gotten hurt worse on the trails then I ever have doing wheelies
Old Aug 23, 2004 | 11:22 AM
  #26
good for you...
Old Aug 23, 2004 | 12:06 PM
  #27
JoshCVBz's Avatar
Originally posted by: 4wheelerfred
good for you...
Sorry...just pointing out how useless your post was. Have a good day! [img]i/expressions/face-icon-small-wink.gif[/img]
Old Aug 23, 2004 | 01:30 PM
  #28
o3VinsonRider's Avatar
Wheelie Tutorial from dirtwheels mag
Of course some quads are easier to wheelie than others. Much of it has to do with the type of transmission and clutch used, while in others the so-called "balance" of the machine—its ability to be ridden at a certain angle for a length of time—factors into the equation as well. Fortunately, all quads made today have a rear grabbar that allows the rider to "overcook" it a bit without tipping all the way over backwards, eliminating most of the fear factor when practicing wheelies for the first time.
Following are step-by-step techniques for wheelies on manual-clutched, and auto-clutched four-wheelers. We’ve also included a list of what we feel are the top 10 wheelie quads made today.
Once you have the front end up in the air, the next step is to find the "balance point" of the machine. On most quads it’s the angle pictured here, a point where the quad feels like it can balance on the two rear tires without falling forward or rearward, with you staying put on the back of the seat. Keep it in this position by using both the clutch and the throttle to control the power, and taps on the rear brake to push the front end down slightly if you feel like you’re tipping over backwards. The trick is to make all of these moves quickly and smoothly so the front end doesn’t drop to the ground and you don’t go the other way and drag the grabbar. Once you can keep the quad at the balance point, you can theoretically wheelie forever. Expert wheelie guys can even shift through the gears.
To start your wheelie with a sport or hi-performance quad, pull in the clutch, shift into first or second, rev it up to around 3/4 throttle, sit back, and pop the clutch. Once you start getting close to the balance point, you can use your arms to slightly push or the pull the front end to the right spot, as well as using the clutch and the throttle. If your quad is always pulling to the right or the left when you’re doing a wheelie, one of your tires has lower air pressure than the other.
Auto-clutch quads are little harder to wheelie, but once you get them up, they’re generally easy to balance since the powerband of their engines is so smooth. To get an auto-clutch quad into a wheelie, depress the foot shifter down but don’t let it pop up yet. Then give the quad about half thottle, let the foot shifter pop up into first and at the same time pull up on the bars. Get your weight back, find the balance point, and off you go.
The wheelie-out-of-a-corner is a stylish move you can use to impress the girls. Simply throw the quad into a slide and just as you’re getting forward momentum, pop the clutch, sit back on the seat, and hang on! Top guys can sometimes do one-wheeled wheelies for a moment, but that maneuver will eventually catch up to you. It is best done in the sand so you don’t scrape yourself or your quad up too much.
DIRT WHEELS TOP 10 WHEELIE QUADS
1. Honda FourTrax 400EX
2. Honda FourTrax 300EX
3. Yamaha Blaster 200
4. Kawasaki Mojave 250
5. Honda Recon 250
6. Suzuki QuadSport LT80
7. Yamaha Banshee 350
8. Yamaha Warrior 350
9. Kawasaki Lakota 300
10. Kawasaki Bayou 220
Old Aug 23, 2004 | 05:07 PM
  #29
DarkManX's Avatar
it dosent tear up ur quad either if u do it rite 4 wheeler fred!
Old Aug 24, 2004 | 07:24 PM
  #30
ok you ppl must be the hard headed ppl from the other thred
