DynoJet Question....need help!!
Old Aug 4, 2004 | 08:51 PM
crazy300ex's Avatar
Default DynoJet Question....need help!!
I am putting on my DMC alien full exhaust on my 300ex and I need help! I also got the DynoJet kit and a K&N airfilter along with it, and I am confused. I went to DMC's website and got the jetting instructions along with the chart that shows which jets to use. My question is which one in the jet kit is the pilot jet? The DMC chart says to use a 40 for the pilot jet, and I cant find a 40 in the kit that I got. There are a few baggies with different size jets ranging from 108-130, but there is no 40. Also there is one baggie without a number, and it is bigger than the other jets. Is that the pilot jet? Id appreciate any help. Thanks guys.
Old Aug 5, 2004 | 09:11 AM
crazy300ex's Avatar
can anyone help me out on this?
Old Aug 5, 2004 | 10:01 AM
crazy300ex's Avatar
ok maybe this might clear up my question above. What is the size of the stock pilot jet in a 300ex? If it is anything other than a 40 (which DMC recommends) i will need to change it.
Old Aug 5, 2004 | 11:31 AM
300exRiderJay's Avatar
I think the stock pilot jet is a 38. if you still can, i would return the jet kit, go to your dealer, and buy a few jets around the size that DMC reccomends for just a few dollars each instead of spending 45 or 50 for the jet kit. you can also pick up a pilot jet there too.
Old Aug 5, 2004 | 11:43 AM
crazy300ex's Avatar
yep, i think thats what im gonna do. i dont even need to use the needle or any of the other jets that come with that kit. DMC says to use the stock needle and leave it in the middle groove, 128 main jet and 40 pilot jet. I wonder if the place I bought the kit from will take it back since I bought as a bundle with a K&N filter.
Old Aug 5, 2004 | 01:51 PM
I don't think they will take it back. You will probably just have to send it back with the air filter, then buy the airfilter seperate. Its only like 27 dollars though.
chop
14
Apr 26, 2001 03:02 PM
DSAPP
Jan 31, 2001 08:34 PM
nightlife7810
Oct 17, 2000 04:36 PM
CG400exMaster
Sep 25, 2000 12:17 PM
RVonSand
Dec 2, 1999 11:41 PM
