400ex wheels hard to get off...
Old Aug 7, 2004 | 04:05 PM
kmoney67954's Avatar
Default 400ex wheels hard to get off...
Hello everyone, I am asking this question for my brother who owns a 2004 Yellow Honda 400 EX. I am wondering if anyone else has a problem getting their wheels to come off? We have to beat them off with a hammer every time we switch from his sand tires to his regular tires. I dont think it should be that hard to get them off and was wondering if anyone knows a fix for this problem? Thanks for any input.
Old Aug 7, 2004 | 04:11 PM
briansgi's Avatar
No they should not be that hard, make sure you clean out your hub splines and the splines on the axle. Best stuff to use is brake cleaner. Alot of people make the mistake of greasing the splines thinking this will make them easier to get on and off, just the opposite, the grease collects dirt and sand and thus making the problem you currently are seeing.
Old Aug 7, 2004 | 04:20 PM
Is this a common problem? We havent put any grease or anything like that on them to make collect dirt.
Old Aug 7, 2004 | 04:30 PM
briansgi's Avatar
Let's just say it's not uncommon to have hubs that are difficult to remove from the axle and sometimes they need some "persuasion"! BTW, where is Rolla Kansas located? I grew up around Parsons several years back.
Old Aug 7, 2004 | 05:15 PM
whatwasthat's Avatar
If i am correct, kmoney is not talking about removing the hubs from the axels, rather, removing the rim from the hub.
Try moving the right rim to the left side next time, perhaps you are tightening the lugs too tight?
Old Aug 7, 2004 | 05:26 PM
Yes Im talking about removing the rim from the hub. I will try that next time and see if it helps. Rolla is in the South Western part of the state. Almost in the corner SW corner.
Old Aug 7, 2004 | 05:29 PM
briansgi's Avatar
At least your fairly close to Little Sahara! My bad on the hubs, I'm so used to removing my MX Hiper's from practice to race.
Old Aug 7, 2004 | 05:45 PM
Yea im kinda close to there, but not close enought to just take off for the afternoon. I usually go to the Beaver Dunes, but they suck!
Old Aug 7, 2004 | 07:36 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
These are aftermarket rims, like ITP or Douglass, right??? You absolutely must RUN WASHERS under tha lug nuts, and TURN THE LUG NUTS UPSIDE DOWN (tapered end out). The lug nut smashes the soft aluminum of the wheel, and makes the hole smaller, every time you tighten the lug nuts. If you keep it up, you will ruin the rims pretty quick!
If this is the stock rims, I don't understand how you could have a problem??? Those holes are huge, and meant to fit the tapered end of the lug nut.
Old Aug 7, 2004 | 10:26 PM
URCRAZY's Avatar
Yes use washers if using the stock lug nuts. If you do not turn them with taper out it will smash the rim hole and squish into the lugs and then it will not come off. When you take the wheels off check your bolts to make sure you did not push the thread in.
I had this problem also from my skats with douglas wheels.
