Rubicon Oil Change
Old Nov 14, 2005 | 03:06 PM
juniorspanker's Avatar
Default Rubicon Oil Change
i ahve a 2002 rubicon and i changed the oil about a month ago. heres what u gotta do. take the skid plate off without breaking any of the bolts (broke both on one side, had to drill them out, huge pain.) then u will see the drain plug and the filter screw. in most all cases it is better to drain the oil before removing the filter. remove filter, add new one, refill with new oil but keep a close eye on the oil level (got side tracked and over filled but not by a whole lot.)
Old Nov 16, 2005 | 03:45 AM
rubiconrider101's Avatar
hey one thing that will help you all out in putting ht skip plate back on which seems to be what your having the most trouble with is flip it up on it's end. once you get the filter back in and fill it with oil, turn the gas off and let it run till it uses up the gas in the carb and lines, remember be sure to put oil in it. then just lock the brakes and grab the front end and pick it up and stand it right on it's end. don't hurt your back. jsut this makes it alot more accesseble and at working level.
Old Nov 16, 2005 | 01:59 PM
bgblk502's Avatar
use a winch lot less back work
ReconBayou
Oct 31, 2022 05:37 PM
shimanok2
Jan 29, 2016 07:37 PM
Sw00p
Sep 24, 2015 02:50 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
patrick.oc123
Sep 15, 2015 02:45 PM
