suspension on 400EX
Old Aug 19, 2004 | 09:28 AM
bullhoggrande's Avatar
Default suspension on 400EX
I am doing alot of high, and long jumping on my 400. Is there a way I can stiffen the rear shock? The fronts are fine, but I have bottomed the rear out a couple of times.
Old Aug 19, 2004 | 09:37 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
You can do two things. Increase the "preload", by tightening the threaded ring at the top of the shock, and/or increasing the "compression damping" (screw at the top of the shock, on the "can"). In general, you want your rear to sag about 3", with you sitting on the bike in full gear. Then you can mess with rebound (screw at the bottom of the shock) and compression damping to fine tune the ride.
See:
http://www.off-road.com/atv/suspension/shockadj.htm
Old Aug 19, 2004 | 09:47 AM
Thanks brother, I never knew that your bike should sit 3" lower with you sitting on it.
Robinhood
Dec 26, 2015 10:28 AM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
