Changin oil in the 400ex
Old Aug 29, 2004 | 02:06 AM
yellow400exman's Avatar
Default Changin oil in the 400ex
This is my first time with a 4-stroke quad or dirtbike. I followed the steps in the user manual for changin the oil. I drained both the oil tank and the tranny. Then filled the oil tank back up and ran it for 5 minutes. Then i went to check the check bolt on the right side( When sittin on the quad) and nothing came out. I want to make sure this is normal. I dont wanna blow the engine. Did i change the oil right? Thanks in advance Jerry
Old Aug 29, 2004 | 02:36 AM
Zingolly's Avatar
I'm sure if you followed the instructions in the owners manual correctly you should be fine.The manual should also give the amount it holds...
lol ...not sure bout that tho my rubicon manual says one thing and it holds more than the manual says..I just read a interesting article on the difference between 4 cycle oil and reg car oil and it is very diff oil be sure you use genuin 4 cycle oil not reg car oil , I only use Honda oil I know
its kind of expensive but its defenitly cheaper then a motor..lol..real expensive for my rubicon it holds almost 6 quarts + filter and its in the $30 range but still better then premature engine wear or damage...Good luck
Old Aug 29, 2004 | 03:07 AM
440EX026's Avatar
Just curious what that article claims the differences are etc.
Old Aug 29, 2004 | 03:22 AM
Zingolly's Avatar
It states the 4 cycle oil doesnt have the API service stamp witch is good for autobiles for energy savings ect..It was a very long article and quite interisting.Things like reg motor oil has agents that make more sliperier then 4 cycle thats why reg oil is bad for wet clutchs etc..and not to use oils that have molybdenum or graphite additives,and not to use energy conservin oils in atvs etc...
Heres the link to the article...http://www.thumperfaq.com/oil.htm
lol...i started reading this one but its really long made me sleepy...http://motorcycleinfo.calsci.com/Oils1.html#Oil
Old Aug 29, 2004 | 03:32 AM
Just to let u know..its Git-R-Done..
Old Aug 29, 2004 | 03:45 AM
Zingolly's Avatar
lol ... when you get older and been married for a while you're not so much gittin it as much as you try getting it...[img]i/expressions/face-icon-small-wink.gif[/img]
Old Aug 29, 2004 | 10:21 AM
Good u fixed the gir-r-done
Old Aug 29, 2004 | 12:36 PM
phibbsie's Avatar
Did you put the oil back in the tranny as well as the oil tank?
Old Aug 30, 2004 | 06:43 PM
I squirted some oil in the check hole and some came out so it was full. Where do u put oil in for the tranny?
Old Aug 30, 2004 | 07:44 PM
warmdye's Avatar
there is no seprate oil resevoir for the tranny.
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
