How to: Turning Radius?
Old Aug 27, 2000 | 11:33 PM
SpeedDemn440's Avatar
what do i have to do to get my turning radius to be sharper and better,etc.
Old Aug 28, 2000 | 12:14 AM
Backcountry's Avatar
Shorter wheelbase. Via a shorter swingarm...A-arms that are forward +1"...or both
Old Aug 28, 2000 | 10:55 AM
THEXOTIC1's Avatar
Or you can put grooved radial tires on the front this will improve your front steering alot. We have these tires on all our bikes. I would ride a bike with out them.
Old Aug 28, 2000 | 11:17 AM
briancwatkins's Avatar
SpeedDemn;
Be sure your front end is aligned properly. Toe-out = large radius, toe-in = equals sharper quicker response. Keep in mind, toe-in could lead to too quick of a response which would result in a wreck. If the alignment is correct, see steps 1-3:
1) Shift your wait to the top of your handlebars.
2) Turn to the desired direction
3) Gas it!
The result is that it pretty much turns on a dime.
[RED]SERIOUSLY:[/RED]
[BLUE]I think my turning radius is about 10'. I can improve this by doing the above procedures. By adding the weight to the handlebars, my front tires grab better and the rear end lightens up. With the rear lightened and the front gripping, I think I am getting a better turn from the machine. Whether or not you need to actually "gas" it is up to you and the predicament you're in.[/BLUE]
That's the best advice I could give you that would "NOT" require modifications.
Old Aug 28, 2000 | 11:50 AM
dhines's Avatar
I have actually heard of some folks shaving down the stops at the end of the steering stem to get a bit tighter turning radius. I haven't tried it personally but I'd love for someone else to give it a shot and let me know how it works!
Dennis
Old Aug 28, 2000 | 04:22 PM
retro's Avatar
In soft dirt or sand, lean forward, turn the bars, hit the front brakes and gas it. When I do this, my quad will pivoton the front inside tire and whip me around. It also helps to shift your weight on your foot pegs, almost like you are going to jump off the side of the quad. This will push the quad the direction you want it to go.
ERIC
Old Aug 31, 2000 | 03:46 PM
derrick's Avatar
I have done it to my wife's 300ex just make sure you don't grind too much away or the bottom of the tie rods will hit the lower a-arm. It made a big difference. (I ground the stops on the steering stem)
Divergent12
Dec 30, 2017 08:33 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Jul 30, 2015 09:39 AM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
