MY 400EX is smoking like crazy....HELP!!!
Old Sep 30, 2004 | 09:22 PM
deftone's Avatar
Default MY 400EX is smoking like crazy....HELP!!!
anyone here have this problem....and if so what is the fix???.....i just changed the oil (which i do often)....i try to change it after every 8 hours of riding (i ride pretty hard)...anyways i just changed the oil and filter and after, it started up pretty hard and once it was running it was putting out a spy hunter style smoke screen....the only thing i did different this time was i unintenional put 2 different brands of oil (same weight) one honda and the other arctic cat.....i don't think this is why but i thought i would give all details....i checked the compression and it is putting out 150 on the comp. tester....
thanks in advanced for the help
tone
Old Sep 30, 2004 | 09:26 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
well idk but could it possibly be getting past the rings!? take it for a ride see if it clears up if not (just a 5min ide if that)
Old Sep 30, 2004 | 10:17 PM
deftone's Avatar
i ripped up and down the road a couple times and it did not clear up.....thanks
tone
Old Sep 30, 2004 | 10:45 PM
Ntrx250xJ's Avatar
400ex and 450r's have the same problem. Over time the valves start to stretch. One thing honda did wrong is use crappy valves. That would explain the hard starting. thats one of the first signs. But it might not be that. Best to take it to a mechanic and have them pull the top end. Could also be a gasket somewhere. good luck.
Old Oct 2, 2004 | 08:37 AM
deftone's Avatar
thanks...i'll look into adjusting the valves and see if it helps....later
tone
Old Oct 2, 2004 | 11:27 AM
hondabuster's Avatar
too much oil in the crankcase? Using two different brands of oil, wont hurt anything. Did you also reoil the air filter...and maybe over do it? Is the crankcase breather, dumping oil into the air box?
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
