400ex question
Old Nov 30, 2004 | 09:12 PM
XxYamahaQuads's Avatar
Default 400ex question
how fast can a 400ex go witha pipe, airbox, new tires, and jetting.
can the new 05's wheelie as good as the older models?
Old Nov 30, 2004 | 09:35 PM
Tander's Avatar
The '05s about 12 pounds heavier than the '04 due to the reverse. To compensate Honda lowered the gearing slightly. So to answer your question.....yes. Mine will wheelie forever.
Old Nov 30, 2004 | 10:00 PM
what about speed,
im thinkin of maybie gettin one and i need this info
ill probably get an 04 or older
Old Nov 30, 2004 | 10:21 PM
come on someone answer my question.
dont u wanna see a yamaha guy go honda
Old Nov 30, 2004 | 10:44 PM
Jordanw's Avatar
hey do u have aney picks of u on ur o5, hoe is it, dose it ride the same as the 04's??
Old Dec 1, 2004 | 01:29 AM
khen's Avatar
Originally posted by: XxYamahaQuads
what about speed,
Are you talking about top speed? If so they hit in the 65-67mph range stock from what I hear, I've never clocked mine.
Old Dec 1, 2004 | 08:05 AM
NCguy84's Avatar
As far as topend goes, the 04 and later 400ex should be faster due to the diff gearing. The gear change that honda made for the 05 was just switching the original 15 tooth front sprocket to a 14 tooth. When i had the 14 tooth on my 04 i topped out at just about 63mph, and with the 15 tooth was about 68. Hope this helps. But to be honest if you can i would get the 05, i wish i would have waited. Now that the 400ex has reverse i believe it will be the best or darn near close to the best trail quad ever made. Just my 2 cents.
Old Dec 1, 2004 | 01:50 PM
Vinson581's Avatar
he is right.
the only reason i opted for what i did was because i dont need reverse for racing, and a brand new regi, titled, never driven 400ex for 2900$ with 300$ boots is had to pass up.
v581
Old Dec 2, 2004 | 10:26 PM
400exROOSTER's Avatar
a 400ex can go fast....mine clocks out at 125km but i only have a k&n air filter and oversized jets...tires don't make a difference as long as there knobby..it also depends on the pipe the best pipe i would say which will give you the most top end would have to be a splash 'n' dirt or a white bros e-series
Old Dec 3, 2004 | 03:23 AM
URCRAZY's Avatar
I got clocked at 71 with mine. My friend has a 450R with the LRD pipe and jetting, He was being clocked with a truck at 83mph.
