Piston? What's better?
Old Dec 14, 2004 | 07:12 PM
OregonDunePatrol's Avatar
Default Piston? What's better?
I have the 13:1 JE - had that in there for over a year with heavy riding every weekend - Never replaced the rod and I run stock studs and its runs really good with no problems whatsoever - ZERO. I just put in the race head with porting and larger valves as well as a light flywheel and twist 1/4 to full throttle.
Just point me to the YFZs and this 260lb 440EX rider will kick butt .....
Old Dec 14, 2004 | 07:48 PM
WheelieKing's Avatar
So its safe to run 94 in my quad if I got the 11:1 Ross piston? What power gains will there be?
Old Dec 14, 2004 | 10:11 PM
NCguy84's Avatar
Thanks for the info guys, i think i am going to go with the 12:1 JE piston, and i will be running 110 octain fuel. Where is the best place to purchase the JE piston from?
Old Dec 15, 2004 | 05:10 PM
cals400ex's Avatar
how much of a difference did that flywheel make?? i just got mine back this week but havne't put it on the bike yet.
Old Dec 15, 2004 | 05:12 PM
  #15
cals400ex's Avatar
without changing the cam, i would say not a ton. with changing the cam, you will get great gains. a good full exhaust makes a pretty big difference when you start doing motor mods. i run that octane on my 11:1. some builders say you should go with higher others say you will be fine. i haven't had any problems.
Old Dec 15, 2004 | 05:13 PM
  #16
cals400ex's Avatar
i would probably buy that piston from GT Thunder. his prices are pretty good.
Old Dec 15, 2004 | 05:24 PM
  #17
Thanks I wasn't planning on just goin with the piston. I was thinkin first full exhaust, then at the same time I would put in a Cam and the Piston.
Old Dec 15, 2004 | 05:29 PM
  #18
You think it would run good with a stage 2 hotcam? Also where can I get a lighter piston pin?
Old Dec 16, 2004 | 05:41 PM
  #19
cals400ex's Avatar
i ordered all my piston and sleeve from C&D racing. they had to special order the piston pin. i am not sure if JE makes one too, but i know ross does because i have it.their # is 308-696-7805. the prices seem to be pretty good to.
Old Dec 17, 2004 | 12:40 PM
  #20
jeepnrocks's Avatar
no problems with wiseco, je had the compression i wanted and i couldn't find a 13:1 wiseco
