400ex neutral problem
Old Dec 11, 2004 | 11:17 PM
Vinson581's Avatar
Default 400ex neutral problem
my new 400ex wont start in neutral? the green neutral indicator doesnt work either anymore?
is there a fuse or something, the thing will only start with the clutch in regardless of if it is in gear or not. any suggestions?
v581
Old Dec 12, 2004 | 05:38 AM
TractorPacker's Avatar
Do you have a balloon?
There is a fuse, but if it starts in neutral, it is not the problem. There is a safety switch in the clutch lever. Check the wires in and out of it. You might need a new clutch perch or the switch that goes in it.
Old Dec 12, 2004 | 11:45 AM
Vinson581's Avatar
it will not start in neutral unless the clutch is pulled in?
Old Dec 12, 2004 | 04:52 PM
atvnatcparts's Avatar
HELLO, I JUST FIXED ONE OF THESE WITH THE SAME PROBLEM,ON THE LEFT SID OF THE MACHINE (AS YOU ARE SITTING ON IT) BY THE FRONT SPROCKET THERE IS A WIRE, IF YOU PULL OFF THE WIRE, THERE IS A BRASS NEUTRAL SAFTEY SWITCH, CHANGE IT WITH A NEW ONE AND THE PROBLEM SHOULD BE FIXED.
Old Dec 12, 2004 | 07:57 PM
Vinson581's Avatar
does the wire go into the motor, or just plug into something? and how much is the part?
Old Dec 12, 2004 | 09:30 PM
there is a brass insert that screws into the side casing, i found a used one on ebay for 20.00 new i think is 50.00.
Old Dec 13, 2004 | 07:30 PM
Vinson581's Avatar
do you have the part number? the fiches arent showing it.
v581
Old Dec 13, 2004 | 07:51 PM
hello, try this link to ronnies, part is $12.00 part five:http://216.37.204.202/Honda_OEM/Hond...e=13&A=53&B=15, this should fix the problem.
Old Dec 13, 2004 | 10:59 PM
Jordanw's Avatar
there should be a wire connecting to the gear box, wigle it a bit if the connection is bad there, that is the problem.
Old Dec 13, 2004 | 11:08 PM
sandman99ex's Avatar
mine did the same then i kicked the b!tch after that it worked just fine
