99 400ex blue smoke?
Old Feb 23, 2005 | 09:12 PM
exxpense's Avatar
Default 99 400ex blue smoke?
I have a 99 400ex (stock everything).The baffle removed.After a high speed run,letting off the throttle results in a slight bit of blue smoke from the tailpipe.No smoke at idle or any other time!! Valve guide seals??
Old Feb 23, 2005 | 11:38 PM
be28936's Avatar
Is the choke stuck on a bit? Maybe the cable need greasing.
Old Feb 24, 2005 | 01:13 AM
StillRacinA250r's Avatar
Sounds like guides are worn or seals are bad.
Old Feb 24, 2005 | 11:02 AM
hondahero53's Avatar
could be a yery small piece of one of your piston rings broke off and only at high rpms oil gets through and that is whats making blue smoke thats what happened with my suzuki 230s
Old Feb 24, 2005 | 11:15 AM
wheelinguy2003's Avatar
be28936...the choke is butterfly valve with a switch directly on the carb...so unless that is broke it cant be that...for blue smoke it can only be valve seals or worn rings....if ring was broke he would be lossing power along with smoke...imo...hope this helps
Old Feb 24, 2005 | 01:26 PM
cals400ex's Avatar
the 400ex's are known to use a bit of oil when ran hard. try switching brands of oil. most don't have a problem once they switch oils. i haven't heard of any problems with people running the mobil 1 15-50 full synthetic. this is what i run and don't have any problems. this oil is now discontinued so we will have to find another good one.
Old Feb 24, 2005 | 07:27 PM
exxpense's Avatar
Thanks for the help everybody!! guess i better dig deep in my pockets for this repair!!
Old Mar 1, 2005 | 11:17 AM
Kdawg's Avatar
really u dont have to dig deep ring are very cheap and gaskets are nothin its just finding someone to put it in for u cheap.
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
