400ex starting trouble
Old Mar 12, 2005 | 09:18 PM
beefcake's Avatar
Default 400ex starting trouble
my ex wont start so i thought it might be the spark plug b/c it had been a while since i had been on it. so me and my buddy started trying to get the sparkplug out and it wasnt gonna happen and we were using the stock honda wrench. everyonce in a while it will try to start do you even think that it is my sparkplug. Also the tube that is underneath your fourwheeler and gas trickles out when you stand the fourwheeler up. gas has been coming out of there for a while now. Could use some help please
Old Mar 12, 2005 | 10:07 PM
FoxProRacing's Avatar
I think the tube is your carb overflow and this his normal that when you stand your 4wheeler the gaz flow of it.The gaz come from the carburator float.
Old Mar 12, 2005 | 10:31 PM
beefcake's Avatar
Could that also be from the engine being flooded possibly?
Old Mar 21, 2005 | 03:52 PM
cals400ex's Avatar
replace the plug. when starting the 400ex, turn the choke on full and pump the throttle 5 or 6 times. then just hit the start button without hitting the gas anymore. our carbs have an accelerator pump and if you keep nailing the gas you will flood the bike.
Old Mar 24, 2005 | 01:05 AM
beefcake's Avatar
Thanks for the help it turned out it was the sparkplug...i finally got it out...but i took some sand paper to it, b/c i didnt have any on hand and it started on the first crank but thanx for the help though.
tycobb
ATC 3-Wheelers
Oct 23, 2015 07:37 PM
DTroyer01
Jul 3, 2015 07:34 AM
Bm400ex
Jun 22, 2015 09:16 AM
1000gade
May 27, 2015 12:37 PM
atving
Nov 17, 1999 09:24 PM
