Rancher 350 - Need more power!!!
Old Mar 31, 2005 | 11:23 PM
BareTread's Avatar
Default Rancher 350 - Need more power!!!
whats the advantage of having a clutch kit put on an atv? would it be worth getting for my rancher?
Old Mar 31, 2005 | 11:29 PM
pat89's Avatar
Highlifter sells a clutch kit for the Rancher. It is designed to be used in conjunction with oversize tires. I would advise not running one unless your machine has problems turning your tires and then only after installing jetting, pipe, and aftermarket filter. How it works is it delays operation of the clutch until a higher RPM is achieved (like a stall speed converter for a car) and then engages allowing your tires to move. This works well in muddy situations but could actually hinder you if rock crawling or even during general trail riding.
Old Apr 1, 2005 | 02:22 AM
BareTread's Avatar
got any pics of your rancher? could you post some?
Old Apr 1, 2005 | 09:16 AM
pat89's Avatar
Try this link: http://pg.photos.yahoo.com/ph/crazykayaker89/my_photos
Old Apr 1, 2005 | 05:17 PM
  #15
BareTread's Avatar
nice pics[img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 1, 2005 | 07:52 PM
  #16
pat89's Avatar
Thanks, I can't wait to get my ITP Type 5s. But first, my Amsteel Blue winch rope and aluminum fairlead should be in next week [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 1, 2005 | 08:57 PM
  #17
extremerider2811's Avatar
is it possible to change a gear ratio in a shaft driven quad? i have the skills to tear it open and put it back togather, but is there a kit????
Old Apr 1, 2005 | 09:55 PM
  #18
Chilly's Avatar
If there is I've not heard of it. It would probably be quite a complicated process due to the clearance and end thrust requirements of a set of bevel gears.
Old Apr 2, 2005 | 10:46 AM
  #19
pat89's Avatar
There's not a kit available, but if there were the possibilities are awesome to ponder.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
byronman
Sep 6, 2015 06:34 PM
Elkaholic
Sep 6, 2015 02:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Logan Collins
Sep 5, 2015 08:03 PM
