jetting question
Old Mar 25, 2005 | 11:04 AM
manual's Avatar
Default jetting question
On my 300ex I have it bored and stroked to a 406. It was running fine for a while than the starter blew. I waited a couple months and decided to fix it. I replaced the starter and started it up. I noticed that when I would pin it and my engine would bog down and after a few seconds it would kick in. I figured my needle was off. So I pulled my carb off and saw a gas puddle laying in the intake ports. I went up to the biggest jet I had on hand which was a 130 something and reminded myself to change it down the road but I forgot until now. Figured I'd need to adjust my intake valves. But while I'm at it I would rejet. What size jet should I go up to. My mods are Suppertrap E.A.R Exhaust, Uni Airfilter, Powroll Valve Springs, Hardend Rockers, Wisceo 11:1 Piston, Bored and stroked to 406, and headowrk.
Old Mar 27, 2005 | 11:28 AM
zippy's Avatar
Your jetting seems to be lean still. WOT is not affected by needle. I had good experience with a jet kit from "jetsrus" com.
Old Mar 28, 2005 | 03:02 PM
cals400ex's Avatar
full throttle could be affected by the needle tip a little bit. i would look closer at the mainjet if your having full throttle problems though.
Cole Hadden
Jun 15, 2025 09:05 AM
MIKEYTRXSHEEBANGS
Dunes and Dune Machines
Aug 27, 2015 12:57 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
