before and after
Top Speed is really not determined by engine displacement....Gearing is where topspeed comes into play...Your topspeed will probably be a little higher with the 440 kit because I think you are able to rev the engine higher...so you will get a little more RPMs out of all the gears and 5th gear than you were previsously...but if you want a much higher top speed you will need to gear it higher via sprocket changes...look for a noticiable change in acceleration though.
Originally posted by: MattKiker
Top Speed is really not determined by engine displacement....Gearing is where topspeed comes into play....
Now forget the hill and consider flat ground, wind resistance, weight of the 4-wheeler, friction on the road all cause the ATV to reach a max speed and that's it. Add more HP and you'll get going faster. If you want the engine to rev higher just keep the throttle in the WOT position and pull in the clutch...she'll rev then.
Power curves can be different depending on how the engine is set up. Things like a high lift cam or a high duration cam can affect this.
