TRX 200 SX Chain & Sprockets
Old Oct 1, 2000 | 06:21 PM
ATV_MAN's Avatar
Well I think it's time to get a new chain and sprockets...I was just out riding and I had just tightend the chain and I went in a creek with shallow water and came out and while I was going up on the creek bank my chain skipped on the back sprocket. I knew for a while I would need a new chain and sprockets but now I need them fast. The teeth are bent and the chain is worn down.
I need to know what kind of chain and sprockets I should get, O-ring chain??, Racing chain??, Aftermarket sprockets??, Honda made sprockets??
What are better for the 200 SX??
(Why don't I just buy a new ATV since everything is starting to go wrong with it??...LOL)
Old Oct 1, 2000 | 06:35 PM
JRM's Avatar
JRM
I bought a RK O ring chain, and a aftermarket front sproket threw the local dealer. The rear sprocket is a honda only item as it has rubber shock pads between the bolt holes. The rear sprocket ran about $70 alone. Always buy a O ring chain otherwise you will be adjusting it every ride.
Old Oct 1, 2000 | 07:52 PM
ATV_MAN's Avatar
I heard the racing chain will do as good as the o-ring...only if you get a really good racing chain.
Old Oct 1, 2000 | 09:27 PM
bermbanger's Avatar
Listen, go to www.denniskirk.com and have them send you a magazine.Aftermarket companies do make rear sprockets for it.My advice would be leave stock gearing,get a heavy duty RK or DID O ring chain and sunstar,moose,or Pro steel sprockets.Get the heavy duty(racing) because the sx is hard on a chain and sprocket.GET THE O RING CHAIN NO MATTER WHAT!!
Old Oct 1, 2000 | 10:22 PM
ATV_MAN's Avatar
Ok thanks for the advice on the o-ring chain
I want to order from the local dealer only, but thanks anyways.
Old Oct 2, 2000 | 05:29 AM
JRM's Avatar
JRM
I ordered the moose and sunstar rear sprockets from dennis kirk, both did not have the same hole pattern and I ened up buying stock after trying another aftermarket co. from the dealer.
Old Oct 2, 2000 | 04:48 PM
ATV_MAN's Avatar
What's better for chain and sprockets...Aftermarket or Honda Factory made??
Old Oct 2, 2000 | 05:22 PM
bermbanger's Avatar
If you look the stock chain is a medium duty RK.(If it isn't its not stock)if you buy from Honda you will be buying the Honda name so go with aftermarket.
Old Oct 2, 2000 | 06:48 PM
ATV_MAN's Avatar
OK I'll order an aftermarket O-ring chain and atermarket sprockets tomorrow....I was gonna order them tonight but the dealer is closed now so I'll do it tomorrow.
(I'll also ask if they are selling any used quads...LOL)
Old Oct 2, 2000 | 07:19 PM
puddding's Avatar
ya got those adjusters sort out yet
ps. everything breaksdown.......sprockets and chains are general wear items....brakes....the age of the quad doesn't help them......the bike is still worth fixing
