i need help with my 250 ex
Old May 3, 2005 | 08:33 PM
Guest
Guest
Posts: n/a
Default i need help with my 250 ex
it shuts off when u put it into gear or rock it but it will idle all day.
Old May 3, 2005 | 09:17 PM
moto93's Avatar
Does it die when you hit the gas? If so it probably has a partially plugged main jet.
Hope this helps,
Old May 3, 2005 | 09:29 PM
Guest
Guest
Posts: n/a
it idle while in gear but dies when you hit the gas
Old May 4, 2005 | 12:13 AM
liquidplumber's Avatar
Make sure you have enough gas in it.
I know it sounds like I am being a wise ***
but I'm not . The little Hondas will idle on fumes
and die when you hit the gas.
Been there done that more times
than I like to admit good luck
Old May 5, 2005 | 09:07 PM
crazyfor4wheels's Avatar
check your jet and spark plug if that is not it you are SOL
