400ex and tighting chain
Old May 9, 2005 | 10:47 PM
400exboy779's Avatar
Default 400ex and tighting chain
I got an 04 400ex and i need to tighten the chain. I looked in the manueal and i did what it said by looseing the fixing bolts but i couldnt get the adujuster to turn. Is there a special tool that i have to use. Any help is appreciated.
Thanks
Old May 9, 2005 | 11:02 PM
TractorPacker's Avatar
Do you have a balloon?
Once the 4 bolts are loose it will turn. It will stick sometimes, so its hard to turn it. I use big pliers when I have to.
Old May 10, 2005 | 01:37 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
One of the large adjusters for rear shock preload works perfectly!
Old May 10, 2005 | 07:56 AM
quad2xtreme's Avatar
Really loosen the 4 bolts then use a screw driver to pry the tube open some. You are basically unsticking the tube from the axle carrier. I just use the 6mm allen wrench that came in the factory tool kit.
Old May 10, 2005 | 09:54 AM
Red Rider
My experience has been that if you use the allen wrench to move the adjuster like they show you in the owners manual, you just end up hacking up the slots.
Old May 10, 2005 | 10:20 AM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
I used allens and it worked fine, then needed 2 pry bars to rotate it. Sucker was tight.
Old May 10, 2005 | 09:30 PM
Jordanw's Avatar
you can also put your skrewdriver etc... throw one of the holes on the sprocket in to the whole and role the bike forword or backwords forget witch...
mrtidy
Feb 3, 2016 05:00 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
