400ex cutting out and backfiring need help QUICK!!!!
Old May 13, 2005 | 05:52 PM
Yellr400EX's Avatar
Default 400ex cutting out and backfiring need help QUICK!!!!
my 400ex is cuttin out and back firing constantly at all rpms this is the third time the first 2 times i cleaned the carb with carb cleaner cleaned the air filter and changed the spark plug and the first 2 times it worked good for about 2 hours and i havent done this yet this time but i was just wonderin what it is if im doin the right thing and why it keeps happening again i need quick any help is grateful.
Old May 13, 2005 | 05:59 PM
1988fast250x's Avatar
sounds like you have the wrong jets in it i would change them to where it ran right looks like your getting 2 much fuel or not enouf one of those take the plastics off and then gas tank where you can get 2 the carb and change them jets youll know when its right but dont put it all back together with out sliding the gas tank back in and the back plastics and ride it around the yard dont bolt nothing back together until its right!!
Old May 13, 2005 | 06:06 PM
Yellr400EX's Avatar
maybe i should add this when i take the spark plug out its a little white i always thought one of the jets maybe gettin a lil clogged from sumthin
Old May 13, 2005 | 09:47 PM
TractorPacker's Avatar
Do you have a balloon?
You are jetted lean. Most likely on the air screw or the pilot go up one size on the pilot jet. Stock is 38 so 40 is the one you'd want.
Old May 14, 2005 | 12:15 AM
hondabuster's Avatar
When you take the carb apart...is there alot of crud in there? You might want to add an inline fuel filter, this will help the carb stay cleaner, longer.
Nosniborpapa
Sep 12, 2015 05:54 PM
Rooky
Sep 9, 2015 03:16 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Brandon400
Sep 7, 2015 12:20 PM
Elkaholic
Sep 6, 2015 02:44 PM
