400ex web cam or hot cam?
Old May 17, 2005 | 09:19 PM
SuzukiRacer51's Avatar
Default 400ex web cam or hot cam?
hey my friend has a 2000 400ex and he wants it to go like a raped ape. And hes just starting to do mods. And he is thinking about cams. I told him i'd do a topic on here and see what you guys think. Whats the best cam for his 400ex? Web cam or hot cam? He wants top speed.
Old May 17, 2005 | 09:58 PM
TractorPacker's Avatar
Do you have a balloon?
You can get a better cam from Web. It will cost between 4 and 5 times more, though. With the big web cams you need hardened rockers, and shortened guides. Thats comes out to about 450, with the cam.
Old May 17, 2005 | 10:05 PM
ok..thanks any others?
Old May 17, 2005 | 10:53 PM
homdaddy's Avatar
i like the megacycle cams if you go to there web site (megacyclecams.com) on page 28 it gives you several opions.
Old May 18, 2005 | 12:57 PM
khen's Avatar
I think the aggressive Mega and Web cams are the best performers but the drop in Hot Cams represent a good compromise between price and performance. The Hot Cam stage 2(or 3 as they are now calling it) is a great top end cam and coupled with a big bore high compression piston, full exhaust and aftermarket CDI gives a great performance gain. If you want to take it a bit further you could then go with a FCR, Edelbrock or 450R carb. Here are some specs(lift and duration) on the different 400EX cams:
Lift Duration@.050"Lift Intake Exhaust Intake Exhaust
stock 400EX cam .316 .302 234 238
XR400 .326 .321 240 244
WB All Around .345 .335 240 248
HRC .350 .339 254 256
GT Thunder .350 .345 256 256
WB Track .350 .345 256 256
WEB 450/451 .350 .345 256 256
WEB 479 .378 .378 250 250
web 463/9i .385 .370 272 270
HOT/stg1 .354 .354 244 244
HOT/stg3 .346 .346 254 254
mega X2 .378 .378 254 254 @.040
mega X6 .402 .385 270 262 @.040
Old May 22, 2005 | 01:38 AM
SpeedDemon13's Avatar
I have a pipe, jets done to my fourwheerl and soon to have k&n would it make a big difference if i got a 450r carb? How much do they cost and where can i find them at?
Old May 22, 2005 | 03:29 PM
cals400ex's Avatar
the 450 carb should help, mainly in throttle response. i would get a cam and piston first.
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
