CDI rev box
Old Oct 12, 2000 | 01:13 AM
Aaron10's Avatar
I'm thinking of buying a rev kit box for my 400ex. I think i'm going to go with one from CT racing. But can someone tell me if this mod really helps? Is it a simple project to do or will it require me to take it to a shop to have it put on?
Old Oct 12, 2000 | 12:27 PM
pudjumper's Avatar
It's pretty simple to install. The cdi box is under the nose plastic and sits in a rubber boot that is hooked to the frame. There are 2 plugs with side clips. Take a look at it it's self explainatory. I've got a new rev box that I'll sell for $60. I live in St. Louis and go to St. Joe all the time. If interested e-mail me.
jkatv400ex@aol
Old Oct 12, 2000 | 05:20 PM
400freak's Avatar
Okay pudjumper I gotta know...why are you selling it?
Old Oct 22, 2000 | 05:55 PM
jonney's Avatar
Aaron i have a friend that had one and it dosn't help unless.It moves the rpms to 10000 right look at power curve. It will only help if you put a High duration cam in it so the power comes on later
Old Oct 22, 2000 | 05:59 PM
jonney's Avatar
Aaron i have a friend that had one and it dosn't help .It moves the rpms to 10000 right, look at
the stock power curve. It will only help if you put a High duration cam in it so the power comes on later.Sorry i didn't read the first response it didn't make sense
Old Oct 23, 2000 | 01:45 AM
400xxx's Avatar
I use a White Bros rev box, it really does make a difference on steep climbs, I can't tell any differnce on the flats though.
Old Oct 23, 2000 | 10:23 AM
Aaron10's Avatar
I don't do alot of climbing. Quite a bit of flat trails at top speeds though, and i hear that the give you more top speed. Also I race TT and on one straight way my bike hits the rev limiter in 3rd and i have to switch to 4th for a split second and then drop back to third. Will the after market CDI help me with this?
Old Oct 23, 2000 | 07:18 PM
1QuickEX's Avatar
The only way you would get more top end from the W.B. cdi, is if you are already bouncing off the rev-limiter wide-open in fifth gear right now.The rev-box allows the motor to spin an extra 1200 rpms. If you can't hit the rev-limiter right now in fifth, don't bother buying one. If you have no mods done to the bike yet, i would actually buy a 14 tooth front spocket for it so it will all the way to the rev-limiter. you'd be suprised at the difference from a 14tooth front sprocket.
Old Oct 23, 2000 | 09:58 PM
400xxx's Avatar
I don't think it will help you. I have never hit fifth wide open with mine, but I can certainly see a major difference wide open in 2nd or 3rd while climbing. All my riding is in the high desert...never MX or TT. Try the 14t sprocket...it makes a huge difference in all gears except 5th
