Extended Brake Lines. NEED HELP QUICK!!!!
I just bout a set of houser +2 a a-arms and i heard for just +2 you can use stock brake lines but one you get into +2+1 or +3 you need extended break lines. Is all this true can i run my stock break lines with just this +2 arms and everything be ok. Thanks
They will probably make the distance, but they will be tight. The gain you get with steel hoses is worth the money you will pay. I think you should buy hoses with stock arms, because you will gain braking power.
I was planning on gettin the stainless brake lines from the beginning but funds were short so decided to go ahead and get the arms since i heard you could do with out extended break lines.
oliveiracarlos
Sep 7, 2015 03:39 AM
