just bought my 450R today
#21
Originally posted by: XracerZ
if you would have read my post correctly. it was a Stock YFZ that i drove not a modded one like your buddy. just by adding a pipe to a YFZ makes a HUGE difference in performance, more so then by adding one to a 450R. the YFZ reacts better to mods then the 450R does. and yes having a 13:1 compression is ALOT of compression your engine is pumping out, and is why you have a good low end.
Originally posted by: khen
I just purchased a used 2004 450R a month ago and I've found the opposite against my buddies modded YFZ. Mine has more power down low and his has more up high. I also have a 13:1 compression piston in mine though, which is probably the difference.
i drove my cousin's neighbor's stock 04' YFZ today, and im going to be honest. that thing has some serious low end snap. "wow" i mean. my 450R has lots of power, but the 450R has all its power at a higher RPM, so it doesnt have that low end snap...
#22
Originally posted by: snowbuster
Well I love my 450r. I feel it has great low end, I just might have to switch to a 13 tooth front sprocket. If that thing had any more of an "instant" snap I think I wouldn’t like it. If I sit back it will wheelie with the punch of the gas if I sit forward enough it wont, ide say perfect. Now I gotta find a yfz to ride and compare. Only if.
Try going in 1st as slow as you possibly can without having it stall...now punch the gas. the 450R hates doing that, doesnt like to be lugged down. and its not as quick of low end as a YFZ. if u try that with a YFZ u will be sorry u did when your laying on your back.. hehe. but like i said, i still like the 450R more because of the mid-high rps powerband.
