450 es no start
Old Jul 13, 2005 | 09:01 PM
eton150's Avatar
Default 450 es no start
?????? does anyone have any idea's a friend of mine has a 03 450es with a no start c/k for fire and yes it's getting fire c/k fusses there ok c/k carb. float + main jet there ok what next. please help.
Old Jul 14, 2005 | 01:35 AM
hondabuster's Avatar
Check to see that fuel gets to the float bowl. Open the drain at the bottom of the float bowl and make sure gas gets there.
Then try starting at 1/4 throttle, this bypasses the idle circuit, and then if the spark plug looks wet...check the compression.
Have you tried a new plug? Did you pull the plug out, and hold it against a ground, and crank, and saw spark?
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
