drilling holes in airbox,is it worth it?
#16
Originally posted by: paintballbanshee
be sure to drill a 7/8 inch hole right through your exhaust pipe also, adds insane power
#18
If you are going to do this, drill the lid, not the box. That way, you can always just buy a new lid and rejet it back to stock if you want. Next, you need to put in fairly large holes(7/8" or 1") and you will need a few of them, maybe start out with 5 or 6. Airbox mods alone will give you very modest power gains, you will really need to replace the stock exhaust also if that is what you are running. You might also want to replace the stock airfilter for a better aftermarket model. Yes, you will have to clean your filter much more often after doing this.
