400ex problem
Old Aug 25, 2005 | 05:45 PM
400EXtreme1's Avatar
Default 400ex problem
K well i was ridin my 2003 400ex nd i was in like low 4th gear not goin to fast then all of a sudden my engine made a wierd noise like it ceased or sumtin. And now it wont start. It was kind of low on oil would that of been the problem?
Old Aug 25, 2005 | 05:57 PM
Hondanutcase's Avatar
How low is low?
Old Aug 25, 2005 | 06:03 PM
about 5mm
Old Aug 25, 2005 | 06:31 PM
quad2xtreme's Avatar
If you engine seized, you would have skidded to a halt. Will the started still it turn over? I've seen plenty of 400exs running that didn't even read on the stick. Sounds like you are still reading the oil level on your stick, right? What if you screw it into the oil tank and take a reading. Does it register on the stick?
Old Aug 25, 2005 | 06:35 PM
Try this first:
Change your plug
Change the oil
Check the gas Make sure it is on
Check your kill switch. Make sure it is on.
See if that works. Otherwise you may be experiencing bigger problems. Your EX may live through running low on oil once, but make sure and check it often.
Old Aug 25, 2005 | 06:43 PM
yes if screw it in it reads. I think im going to have to try the spark plug nd oil thing hopefully thats it.
Old Aug 26, 2005 | 12:11 AM
Wreckless400ex's Avatar
I dunno if this is it but it is always worth a try... you could have sucked something nasty into your carb and its not getting any fuel, i would almost check the carb before jumping to conclusions that you ceased your engine, who knows it might work it might, Also the spark plug is a good thought cause i know if my bike gets a foul plug or its getting bad spark my 400 doesn't like to start, i have exsperienced this when i load my bike up and leave the choke and gas on and find out when i get to the dunes i got a bad plug and she won't fire, i dunno if any of these will work im just puttin my 2 cents in
Bill
Old Aug 26, 2005 | 03:51 AM
400eecksRider's Avatar
do what hondanutcase said to do.
Old Aug 26, 2005 | 01:55 PM
Thanks guys yes i found out i didnt cieze the engine. I was told it was probably the spark or loose wires tHanks for everthing guys
Old Aug 26, 2005 | 02:20 PM
PhatDave's Avatar
i recently ran mine out of oil (long story dont ask!!!) it will still turn over it just wont run, when i took the oil distick out it was steaming,it didnt lock the wheels, it just ran at very low rpm then quit. not sure what it was, i am boring it out to a 426 and getting a Big Gun EVO X full exhaust and jet kit.
