Checking oil on Rancher
Old Oct 23, 2000 | 11:01 PM
jboz's Avatar
I have a question about checking the oil level on my Rancher. When i check it do i screw the dipstick all the way in or just stick it down until it stops?
thnx
Jay
2000 Rancher 4x4 es
the orange crush
Old Oct 23, 2000 | 11:53 PM
cartman308's Avatar
do you have the owners manual for your rancher???
you just put it in until it stops. don't screw it back in.
Old Oct 24, 2000 | 12:55 AM
TEXMud's Avatar
In the owners manual it states to let the engine idle for 5 minutes on a level surface, cut the engine and then check the oil. Yes you are supposed to screw it in all the way to get the right level.
Old Oct 24, 2000 | 01:15 AM
foots22's Avatar
I was told by the tech. at the honda shop, not to screw the dip stick in. I was told to just stick it in until it stopped and then take it out and check it. I was just told this when I went thought the Pre-check with the tech. 3 days ago when I bought my Rancher. I will take a look at the manual too, to see what it says. Hope this helps. Foots
Old Oct 24, 2000 | 12:53 PM
tempest's Avatar
My understanding is that you do not screw the dipstick in but rather just push it in as far as it goes. If you screw it in then when you change the oil and put in the recommemded amount it will show as over full.
Temp
Old Oct 24, 2000 | 01:18 PM
hiofcer's Avatar
For a correct and accurate reading, Don't screw it in. The owners manual states this very clearly.
Old Oct 24, 2000 | 06:28 PM
jboz's Avatar
Thnx for the info guys. I guess i go with the majority and check it when it stops. Yes i have the manual Cartman, but that is the last resort is to read it isnt it. Just kidding. Thnx
Jay
2000 Rancher 4x4 es
the orange crush
Old Oct 24, 2000 | 10:09 PM
TEXMud's Avatar
Sorry for my mistake guys.
Old Oct 25, 2000 | 05:26 PM
cartman308's Avatar
we'll forgive you this time TEXMud but dont let it happen again
i know what ya mean jboz....real men don't need instructions. i wonder why i never was anygood at putin legos together like the picture on the box?????
Old Oct 26, 2000 | 12:25 PM
Luther's Avatar
The dip stick should not be screwed in to get the correct level as the manual states. I had a problem with a new 2x4 2001 Rancher, the first 100 miles I rode I noticed that there was oil being pumped out of an over flow hose onto the exhaust pipe and head. The dealer I bought it from cleaned it off and checked it over and found nothing. When I got it back home I decided to change the oil ,so I looked in the the 2001 owners manual and it said add 2.7 qts. per change w/filter. I did this and the dip stick read over full. Just for kicks I checked my 2000 Rancher's owners manual and it said to only use 2.1 qts.I drained out .5-.6 qts and the stick read the correct level. The 2001 owners manual must be miss-printed where is states to add 2.7 qts. I called the dealer and informed him my finding the manuals being different. He said that the 2000 and 2001 are the same as far as he knows and also said my oil leak problem was probably just over filled at the dealer when it was checked out. Any way I have not had a problem since.
slowgsxr97
Mar 18, 2022 03:40 AM
Blueholleroffroadpark
Where to Ride
Jul 30, 2015 05:39 PM
Scottma518
Jul 16, 2015 09:19 PM
RedRancher
Jul 10, 2015 06:36 PM
Scottma518
Jul 10, 2015 12:42 AM
