My 400 won't start. WHY????
Old Oct 27, 2000 | 09:17 PM
  #21
philzie's Avatar
Pull the air box lid. Similar thing happened to me. It wouldn't start, I checked the airbox and the air filter had fallen off and flipped around. The rubber end of the filter was blocking the intake. The motor would fire off once in a while, but not run at all.
Old Oct 27, 2000 | 10:17 PM
  #22
blaster13's Avatar
I checked the filter, its on there fine. I'm pretty sure I just need a new plug. I'm going first thing in the morning to get one. I went to Pep Boys today and they didn't have the right one.
Old Oct 28, 2000 | 01:39 PM
  #23
blaster13's Avatar
Well, I got the new plugs. I put the plug in and guess what, absolutely nothing. It still won't start up. I am getting really mad. I am just taking it to the dealer because I can't figure out what it is. Thanks for all the help.
Old Oct 29, 2000 | 09:48 AM
  #24
Brad400ex's Avatar
Change the plug. It always works on my EX
Old Oct 29, 2000 | 09:49 AM
  #25
Brad400ex's Avatar
Sounds like you don't know how to tighten a screw tight.
Old Oct 29, 2000 | 09:50 AM
  #26
Brad400ex's Avatar
Pep Boys?? Go to a motorsysle shop and get a Honda Plug. Its a DPR8Z.
Old Oct 29, 2000 | 09:59 AM
  #27
blaster13's Avatar
Brad400ex: It seems you are a little behind in this post. I already stated that I had gotten the new plugs, but they did not work. The only reason I said I was going to check Pep Boys was because the nearest dealer is about 30 minutes away and Pep Boys is about 5 minutes away. Thanks. And I do know how to tighten a screw.
Old Oct 29, 2000 | 01:47 PM
  #28
Buckeye400EX's Avatar
Try cleaning the coil. This is of the left side of the quad as you sit on it. Up against the frame under the gas tank. Take it off clean all connections, put it back on with some dielectric grease on all the connections. Same thing happened to my quad. I'll bet that's the problem.
Old Oct 29, 2000 | 07:21 PM
  #29
1QuickEX's Avatar
I say either your pilot jet is plugged up or your cdi box crapped out on ya.
Old Oct 30, 2000 | 11:31 AM
  #30
SLB300EX's Avatar
Blaster13, let me know what went wrong will you... for future reference.
Good luck and I hope it don't end up costing you out the ***.
