250ex Engine Noise
Old Jan 18, 2006 | 10:48 PM
norcatalyst126's Avatar
Default 250ex Engine Noise
I'm fairly new to ATV's so I don't know too much about them, yet. I have an '01 Honda 250ex and it runs fine, however lately I have noticed an engine "ticking". Also, it sounds like the gearing or transmission is clanking around. Anyone have any thoughts or ideas? I checked the oil and it doesn't seem contaminated and is fairly clean. Thanks, if you can help.
Old Jan 19, 2006 | 12:08 AM
be28936's Avatar
I also have an 01 and the gears clank around when i start in to high of a gear. If you start in to high of a gear this might be the problem. For the engine ticking i couldn't tell you if it is normal or not without hearing it.
Old Jan 20, 2006 | 02:22 AM
^BUMP^
Old Jan 20, 2006 | 12:01 PM
TheTurtle's Avatar
the ticking you are hearing is most likely the cam and valves. it is normal...i wouldnt worry about it. the 250ex is a tank.
ronnierhino06
Nov 9, 2015 12:56 PM
hondarider1234
Jul 21, 2015 11:53 PM
cSchwartz
Jul 9, 2015 02:40 PM
Rider252
Jul 6, 2015 03:37 PM
D-Hagz
Jul 4, 2015 02:19 AM
