3 angle valve job on 400ex
Old Nov 10, 2000 | 10:11 PM
nc400ex01's Avatar
got a qestion....i heard the angle job on your valves will really pep the ex up, but is this true and how much will it help....is this the same as "port and polishing head work" just wanted to know because im fixing to get allot of motor work done to shut these yamy boys up....thanks
Old Nov 11, 2000 | 10:58 AM
426ex's Avatar
yes it is!!!!!!!!!!!!!!!!
Old Nov 11, 2000 | 10:14 PM
aar0's Avatar
What is involved in an valve angle job on a 400ex, and what are the bennefits in performance?
Thanks,
Anthony
Old Nov 11, 2000 | 11:59 PM
luckywilson's Avatar
Save your money and save your time. You will never know it was done.
Old Nov 12, 2000 | 02:58 PM
426ex's Avatar
i run right with the ds650 with the stage 1 kit on. you have to do it all to get the full effect
on what it is intended to do!!!!!!!
99 426ex,11:1,web cam,3 angle port job,rev box,
dyno jet kit,6 air box vents,super trapp pipe,
= lots of power!
Old Nov 12, 2000 | 04:02 PM
Dill's Avatar
porting is not in the valves, it is done in the head to increase flow
Old Nov 12, 2000 | 06:26 PM
01TRX400EX's Avatar
a 3 angle valve job just refers to the way the valve seat is cut, on your EX you wouldn't even be able to tell it was done.
put that money into a higher compression piston and a slightly more aggressive cam, and you would have something
Leo
Johnny Mac
60
Dec 14, 2019 06:13 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
