TRX300 4x4 exhaust systems
Old Jun 17, 2006 | 09:59 AM
ftwflh's Avatar
Default TRX300 4x4 exhaust systems
Is there any aftermarket exhaust systems for the older TRX300 4x4s.If so could you post a link.
Need one to fit a 95 model.
Old Jun 17, 2006 | 10:46 AM
Harw's Avatar
Cobra makes a nice one I have used many times. It is a full system. There is just no heat shield for your leg.
Old Jun 17, 2006 | 02:31 PM
ftwflh's Avatar
We ran a Cobra on a 250 Timberwolf and it was extreemly loud.
Old Jun 18, 2006 | 03:20 AM
KNOWSALOT's Avatar
The Facility
Cobras are extremely loud. Even the utility series with the spark arrestor.
You need the one made by ArmorTech. It looks very close to factory and it is as quite as factory. The full length exhaust from engine rearward runs about $150.00
Nearly all dealerships are set up to order this brand. Do some searching and I am sure you will likely find them on the tinternet as well.
The one downside to the ArmorTech is the paint process they use on the exhaust. It is not powder coated and it doesn't retain it's finish long at all. I would suggest anyone buying one to have it painted at an exhaust shop before installation......if you didnt have the right stuff to do it yourself that is.
Old Jun 19, 2006 | 12:06 PM
Harw's Avatar
The system DG makes for the 300 4x4 is the Utility system. It is not much louder than stock. It will make the quad run better. The ArmorTech one is a stock replacement with no performance gain.
Bonzhonda300ex
Sep 17, 2015 10:44 AM
Sep 10, 2015 01:56 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
Bigtwin700
Sep 9, 2015 09:32 AM
Elkaholic
Sep 6, 2015 02:44 PM
