honda 300ex idle adjusting
Old Jul 9, 2006 | 11:51 PM
hondaoperator's Avatar
Default honda 300ex idle adjusting
how can you adjust the idol speed on the atv because the rev is way to loud
Old Jul 10, 2006 | 01:06 PM
where is the idle speed located
Old Jul 12, 2006 | 08:21 PM
Mainboard's Avatar
it is on the carborator..its a little bolt with a spring..
Old Jul 12, 2006 | 08:40 PM
Floorit's Avatar
To be more exact...it's on the same side of the carburator as the choke [left] You should see a large screw with the head facing you. Counter clockwise to idle up, clockwise to idle down.
Old Jul 12, 2006 | 11:10 PM
there is a big, flat head screw that has a big cable
Old Jul 12, 2006 | 11:11 PM
that is a big cable
Old Jul 12, 2006 | 11:26 PM
TractorPacker's Avatar
Do you have a balloon?
Thats the one. When the quad is warmed up, turn it, till you like the idle rpm.
Old Jul 13, 2006 | 12:37 AM
but when i turn it there is no change
but i did turn it counter clockwise because when i turned it clockwise it it got louder, so when i turned the other way about 10x more there was no change
Old Jul 13, 2006 | 01:04 AM
That would mean you are turned all the way down.
Old Jul 13, 2006 | 01:17 AM
Floorit's Avatar
You might want to try taking the throttle apart [on the handle bars], or taking some tension off the cable to see if that does it.
Also......the cable may be kinked causing the idle to be high like that. Trace the throttle cable to see. [might have to remove the fuel tank]
