About the TRX90....
Old Nov 22, 2006 | 09:52 PM
HondaBoy3113's Avatar
Default About the TRX90....
The trx 90, goes about 30, if you where to put a pipe,jets,and K&n AirFilter, how much more Mph whould that give it, please i really want to know.
Old Nov 23, 2006 | 12:35 PM
Scooter86's Avatar
Knows Old ATV Questions!
If you want more top end, you are going to need to change the gearing. Adding power will help then. Stock gearing seems to be the limitimg factor here.
Old Nov 23, 2006 | 04:14 PM
Ok, thanks but how do you change your gears????
Old Nov 23, 2006 | 11:51 PM
Scooter86's Avatar
You need to change the sprockets, nothing with the tranny. Bigger front sprocket or smaller rear sprocket. For wht it is worth, I think it is geared pretty well stock. Maybe after you get that motor built up, going up 1 tooth in the front will do ya.
Old Nov 24, 2006 | 01:20 AM
ok, thanks alot dude, but what do you mean"when you bild the engine up", like bord it out to the 125cc???
