400EX SET UP QUESTION?
Old Dec 10, 2000 | 11:39 PM
radchad's Avatar
I have a 400ex. It is bored out 40 over. I have holeshot tires(22 inchers).My sprockets are; the back is still stock and the front is one tooth bigger. (there are many many other accecories)
Is this set up, good or bad. I have heard that haveing 22 inchers and a bigger sprocket takes away alot of power. is this true? It seems to me that it is a little harder to do wheelies now that i have 22's on. If this does take power away, what should i do? put my stock sprocket back on?
Thanx
Old Dec 11, 2000 | 12:00 AM
TRAX400's Avatar
Go to a 14 tooth spocket up front and try that.
Old Dec 11, 2000 | 02:08 AM
hot_shoe_cv's Avatar
radchad,
Running a bigger or smaller tire doesn't reduce power, it merely puts in in another part of the band. The "power" is still there in your case except it's at the high end of the band due to running taller gearing with the larger c/s sprocket. It just depends on what your priorities are. If you main concern is just doing wheelies just use the 14 or even a 13 c/s sprocket and expect to lose some top end performance. The alternative to all this is to run 20" tires when you replace your present ones with your current gearing. You'd lose 1" inch of ground clearance, however.
Old Dec 11, 2000 | 08:05 AM
01TRX400EX's Avatar
Putting a larger rear tire on effectively gears the machine up... (like when you added the 16 tooth countershaft sprocket)... try running your stock 15 tooth sprocket, and it should bring you back close to where you where before you went with the larger tire...
Leo
Old Dec 11, 2000 | 06:41 PM
radchad's Avatar
thanx everyone. thats what i am just going to do. put my stock sprocket back on and when my holeshots get wore down, ill put the bigger sprocket on with a 20" tire.
wendal
May 9, 2024 09:29 PM
bigred20653
Oct 2, 2015 10:05 AM
wendal
Sep 15, 2015 01:50 PM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
