honda 250 es not ideling
Old Jan 21, 2007 | 07:43 PM
hondaeater69's Avatar
Default honda 250 es not ideling
does anyone know how to get a honda recon es to idel i cant get my daughters atv to idel at all
Old Jan 21, 2007 | 09:15 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
It is frequently necessary to turn the idle up a little when the weather turns cold. There is an idle screw on the side of the carburator, and your owner's manual will point out where it is. Turn it in a little.
Old Jan 22, 2007 | 12:58 AM
hondabuster's Avatar
Either that, or the pilot jet is plugged. Does it idle ok with the choke on? but then dies when the choke is moved off?
Old Jan 22, 2007 | 04:22 AM
rokkorex's Avatar
also check the air cleaner and turn up the idle a bit mine did the same thing i'ts all good now
Old Jan 22, 2007 | 02:38 PM
wont idel on choke or off choke i can drive it and it runs good untill you let off gas
Old Jan 22, 2007 | 04:53 PM
If turning up the idle speed doent help, and the mixure screw adjustment isnt all the way in, id say the pilot jet is plugged solid. The float bowl will need to come off, and the jet removed and either the obstruction needs to be cleaned out and if its in there too solidly, just replace the jet.
Old Mar 18, 2007 | 08:57 AM
usry's Avatar
If none of this works bring it in to a dealor(last option).
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
Jason Campbell
Sep 7, 2015 02:25 PM
